Re: gas cap style
Posted by sflem849 on July 30, 2012 at 06:11:07 from (69.197.84.39):
In Reply to: gas cap style posted by Paulginmn on July 29, 2012 at 17:39:31:
This is from the www.ihgascap.com website.
[quote:94b7c5cacb]A serious fire can occur during operation of a GASOLINE fueled tractor. Under certain conditions, gasoline vapors can build up pressure in the gas tank. If the gas tank cap is then removed, while the engine is running or hot, the sudden release of pressure could force gasoline out of the tank and result in a fire. Gasoline can also escape if the gas cap is not securely tightened. Never remove a gas cap from a hot or running tractor. Always tighten the cap securely. A new style gas cap, first available in 1980, has special design features to reduce gasoline vapor build-up and fuel eruption due to improper gas cap removal. The new gas cap has two vent holes in the top of the cap and has “PRESSURE - OPEN SLOWLY” embossed on the top of the cap.[/quote:94b7c5cacb]
This post was edited by sflem849 at 06:11:31 07/30/12.
