Posted by arod on July 30, 2012 at 06:45:35 from (67.52.234.226):
Pulled the moline plow from the shed and took it out to the edge of the hayfield to get it in good order for Fall, and WOW was that sod like concrete. I am wanting to learn how to adjust the 2 levers on that plow. The only way we could get the plow to catch a point and dig in was to adjust the depth deeper than we wanted, and our Farmall H could barely, and by barely I mean clutch slipping, barely pull the thing in the ground at full throttle first gear. So, how does a fella adjust those levers properly?
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
