Measure the discs. They are 1/2 inch thick when new. If they are still that measurement, put all parts, the two discs and the actuator in the drum and then lay a straight edge across to measure operating clearance. You only need about .030 clearance but you will want to leave more than that just to make sure you don't take off too much. Machine that drum off so you have about .060 clearance. You probably have about 1/8 inch now. If you study that actuator, see all the pressure points, the leverage on the linkage etc you will see why you lose leverage as it expands as the two points come closer together. If you really want it right you will machine all the worn and scored surfaces and then establish the clearance. On the 656 tractors and others they used shims to establish the proper clearance. That is the major adjustment on those models and the threaded adjustment was the minor one. Of course, all expanding points inside and outside of actuator need to be polished and I lube them lightly, balls , ramps, and machined ramps inside drum and outside of actuator.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
