You should not have the water boiling at the top your block has some of the passages plugged. When the tractor is being used hard the temp at the top will be around 170-180 but after many yrs the holes at the bottom in the block get plugged or built up with enough crud water just doesent flow good. ive replaced enough sleeves and have found many with the holes plugged solid with crud smoemtimes pretty thick. If you arent using it hard you will be OK You can fill the system with Vinegar and run that for a while then drain and you will get a lot of it removed. Best way is remove the radiator and backflush out the top of the block.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
