Re: W4 won't run
Posted by El Toro on July 31, 2012 at 03:50:13 from (108.3.148.85):
In Reply to: W4 won't run posted by black on July 30, 2012 at 15:16:42:
If you have good flow from tank to carb. Remove the tube fitting where your gas line connects and look for a screen that may be plugged. Make sure that main jet adjusting scr?w is opened enough near the bottom of the carburetor. Hal
