Posted by wilson ind on July 31, 2012 at 05:14:35 from (70.239.85.115):
In Reply to: Almost ready to paint posted by Fullers Farmalls on July 30, 2012 at 20:28:20:
I'm on your side it's your tractor do as you like Personally I have had best results with van cycle from orshlins and other stores I use thier hardner and (hold on to your hat) regularRESH gasoline for thinner. I put hardner in spray can first as hardnes seems to have lots of thinning effect. Then not much gas is required. I have had problems adding hardner in all paint befors starting for me I add hardner with each fill of spray. The cheap 20 doller gravety paint guns from harbor freight with plastic hopper on top do me as good or better job than siphon gun also all paint is used not like small amount left in bottin on syphon type good luck
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
