Transmission stuck in two gears wouldn't cause a "stumble." The tractor would just smoothly quit when you dump the clutch.
Try giving the tractor a little choke when you let out the clutch. If it's better, the carb needs more work.
Even if the governor isn't responding, the tractor should be able to move itself on flat ground. A non-responsive governor would also be a SMOOTH quit, not a "stumble."
Carburetors can be tricky especially if you're new at working on them.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
