Posted by Dean Olson on July 31, 2012 at 09:28:56 from (75.53.96.101):
In Reply to: overheating/Farmall A posted by gene smith on July 31, 2012 at 08:34:57:
More info please. What's it doing? Do you have a gauge on it? I fill mine up to about 2" below the top. If I overfilled it will burp out the excess as it warms up. That is normal.
The 1st thermosiphon system I had I thought it was getting hot. It wasn't!
If circulation is good you don't have a problem.
Stick a hand held thermometer in the top of the radiator and see what it says.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
