Posted by gene bender on July 31, 2012 at 11:33:44 from (67.55.226.123):
In Reply to: overheating/Farmall A posted by gene smith on July 31, 2012 at 08:34:57:
The # you posted is part# of the block. Serial# is behind the throttle rod under #1 sront spark plug. The gurgiling sound is what other post says the block is probably plugged somewhat in those hole areas. You can remove the radiator and lower outlet and using compressd air and some stiff wire get most of the gunk out your operatinf temp is in the range so you are in pretty good shape. Removing the hea will not get to that area the sleeve needs to be removed to do a complete cleaning.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
