Re: m farmall problem
Posted by rustcollector on July 31, 2012 at 11:58:16 from (166.249.200.103):
In Reply to: m farmall problem posted by k dub on July 31, 2012 at 10:42:47:
Don't assume that just because a spark jumped a plug out of the cylinder that the plug will fire under compression. Swap cylinders with the plug and see if the miss follows. Heat the plug to red hot with a torch, install it still warm and see if it fires.
