Re: m farmall problem
Posted by The Red on July 31, 2012 at 12:17:42 from (206.246.187.69):
In Reply to: m farmall problem posted by k dub on July 31, 2012 at 10:42:47:
If 3# is still dead after swapping plugs, swap plug wires. I bought a 1941M several years back. When it was delivered the fellow said "sounds good don't it". I said "sure on 2 cylinders". Ended up being bad plug wires.
