Re: Hydraulic Pressure
Posted by IH fan on July 31, 2012 at 15:38:15 from (108.220.171.14):
In Reply to: Hydraulic Pressure posted by Aaron Roebkes on July 30, 2012 at 15:24:42:
There are two ways to stop the load from dropping as the valve is moved. One is valve timing, where the port you are moving to opens before the return side does. this is not the best way as pressure starts to build before the return opens and if held in that position, the flow will dump over the relief valve and just build heat. Second, and the better way, is with "lift checks". with lift checks, the return is held with a pressure controlled check valve, where as the pressure comes up on the port being pressurized, a pilot flow opens the lift check. Either way will prevent the load from dropping when you move the valve. If yours is doing that now, my "guess" is a lift check is damaged some how.
This post was edited by IH fan at 15:38:39 07/31/12.
