Yes, his website is: http://jacksonpowersteering.com/
But I want to fix the 350 the same as factory.
The old roller ball bearings/races in the steering valve assembly are IH made I think. No aftermarket parts. That is what I have now and the races are rough. They made a change to roller needle/washers. Then stopped making the parts soon after. Wish I had the parts specifications I would get a few made of new. I have notion to go and get them made. This is a great utility tractor.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
