Re: m farmall problem
Posted by ken house on July 31, 2012 at 16:06:29 from (173.242.240.50):
In Reply to: m farmall problem posted by k dub on July 31, 2012 at 10:42:47:
very easy to wire plugs backwards. remove distributor cap, crank engine so you can see which way rotor button is moving and make any necessary adjustments. then remove rocker arm cover and crank engine, to see if there is a stuck valve.
