THe sleeves are worth removing, as they just push out the top with a block of wood and a 2 pound hammer. The pulley will not come off easily. if it has a set screw, it will be obvious. Most are interference pressed fit. I have seen some take 15 ton of hydraulic pressure, and very good support to get them to budge. Heat the pulley shank (not red) and it will come easier. The use of a Good bearing splitter behind the pulley, and a press is often needed. Sand the two to allow a less dramatic reinstall. (not so as to make it slip on though!) Bearing pullers with arms will break the pulley at 30% of the needed force! Jim
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
