Re: Remove Sleeves or Not?
Posted by JRSutton on August 01, 2012 at 03:06:14 from (75.130.109.233):
In Reply to: Remove Sleeves or Not? posted by equeen on July 31, 2012 at 21:25:46:
third party image
What's broken on the block?
It's usually a lot easier to pull that front pulley while the crank is still installed -
I was impatatient one day and rigged this up to pull my pulley on the super a - it bent the threaded rod quite a bit, moaned and groaned, but it came off.
I post the picture not to suggest you do it this way - but to give you an idea of what's needed.
(also used a lot of heat)
Just be careful - any time you're working with extreme pressures (and especially with parts not designed for the job) peices can go ballistic when it fails.
