Posted by El Toro on August 01, 2012 at 04:01:26 from (108.3.148.85):
In Reply to: Engine SN/Date Code posted by equeen on July 31, 2012 at 21:09:35:
You don't need the engine serial number for parts. That engine block is also used on the Super C tractors. Measure the old sleeves should be 7-1/32" in length. You can buy an overbore sleeve kit and the sleeve bore and piston diameter is 3-1/4" to give you 133cid. No machining is required on this block. The late Super A's and Super C's used this block. Hal PS: Have that crankshaft measured for wear at your local auto machine shop. Buy your bearings from them.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
