Re: farmall F20 not starting
Posted by robgIN on August 01, 2012 at 04:16:48 from (76.208.8.129):
In Reply to: farmall F20 not starting posted by ironmesh on July 31, 2012 at 22:32:13:
did you check to see if you have spark ? Usually if you have a flooding problem you have fuel dripping out the bottom of the carb. Are you getting plenty of fuel to the carb? Take the drain plug out of the bottom and make sure you have good flow. I would suspect a condenser problem.
