Re: Remove Sleeves or Not?
Posted by sflem849 on August 01, 2012 at 10:15:15 from (166.182.3.71):
In Reply to: Remove Sleeves or Not? posted by equeen on July 31, 2012 at 21:25:46:
Do you have to measure wet block sleeves before removal? I used a bearing splitter and a big two jaw puller to remove my crank pulley.
