Re: Farmall 560 Diesel valve cover??
Posted by pete 23 on August 01, 2012 at 11:26:15 from (74.32.238.2):
In Reply to: Re: Farmall 560 Diesel valve cover?? posted by rustred on August 01, 2012 at 08:29:25:
Don't need to split to remove head, but because that baffle under the fuel tank is spot welded on you better raise that tank up. I pulled lots of heads on the gas tractors with the bolted on baffle with out raising fuel tank but even with that light head it is a two man job to put it back on unless you have a tilt attachment on a cherry picker. And yes, the valve cover comes off after removing intake manifold.
