Re: 656 Diesel d282 won't run
Posted by Owen Aaland on August 01, 2012 at 16:43:06 from (216.47.35.3):
In Reply to: 656 Diesel d282 won't run posted by Dan Osborne on July 31, 2012 at 10:23:06:
The engines in the Hydrostatic transmission tractors are set to run at a high rpm that the gear drive tractors.
Low idle: 650 (+\- 25)
High idle: 2580 (+\- 10)
Rated speed: 2300 (+\- 10)
Minimum overload speed: 1600 (+\- 25)
