Re: Headlight 6 volt System 12 on 47 cub can i still use them
Posted by Paul Shuler Oh yeah! on October 05, 2000 at 18:51:28 from (152.163.207.182):
In Reply to: Headlight 6 volt System 12 on 47 cub can i still use them posted by George Herrin on October 05, 2000 at 18:37:32:
Hey you sure can use them. All you need to is go to your local auto part's store and take your 6 volt bulbs and they will give you the proper 12 volt bulb that will fit just right.I just bought some for my super C on Monday at O'riely auto parts store. They had some made by wagner that are 12 volt with 32 candle power that will make you see spots for a while if you look into them. Cost was $2:00 each.I do belive that if you try and use your 6 volt bulbs with your 12 volt alt it will more than likely pop them. It should be marked on the bulb if the ones you have are 6 or 12
Post A Followup
: Re: Re: Headlight 6 volt System 12 on 47 cub can i still use them
