Re: Farmall Super C new sleeves... should we put sleeves ...
Posted by Red Dave on August 01, 2012 at 17:21:17 from (98.235.13.108):
In Reply to: Farmall Super C new sleeves... should we put sleeves in f... posted by David R Inman on August 01, 2012 at 16:41:45:
The freezer trick is used sometimes for dry sleeves to reduce the o.d. a little for easier installation.
Your Super C has wet sleeves, you should not need to put them in the freezer to get them in.
I use a little soapy water, but any of the suggestions by the other posters should work for you.
