Posted by El Toro on August 02, 2012 at 03:52:16 from (108.3.148.85):
In Reply to: Wet/Dry Sleeve?? posted by equeen on August 01, 2012 at 19:33:07:
Dry sleeves are usually a dry press fit and wet sleeves can be installed by hand. You need to clean that block area where your old sleeve seals are or were installed. Use a wire brush on a drill motor. Use a good lite in that area to make sure there's no crud in that block area to restrict coolant flow. Hal PS: I used a piece of 2 x 2 oak and a big hammer to remove the sleeves from a Farmall A in 1975.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
