Re: Farmall Super C new sleeves... should we put sleeves ...
Posted by El Toro on August 02, 2012 at 03:59:17 from (108.3.148.85):
In Reply to: Farmall Super C new sleeves... should we put sleeves in f... posted by David R Inman on August 01, 2012 at 16:41:45:
Just coat the end of the sleeve with dish detergent so it will slide thru the new seal. Make you clean that block area where the old sleeve seals were installed. Use a drill motor and a wire brush. Use a good lite and also look in the bottom of the block for any crud as this might restrict coolant flow. Hal
PS: Clean that recessed area at the top of the block so your new sleeves will seat.
