Posted by mkirsch on August 02, 2012 at 05:30:13 from (64.80.110.75):
In Reply to: Super C Hydrolic Lift posted by Stephenscity on August 01, 2012 at 08:54:17:
How do you want to lift this trailer plow?
Do you want to pick the ENTIRE plow completely up off the ground? That doesn't seem particularly practical. Even a 2-bottom plow weighs several hundred pounds, so you'd have to work out the mechanical advantage to where you only have a few inches of lift.
Do you mean in and out of the ground? That's a little more realistic.
Caterpillar used to have cable lift systems for their implements, and there's a lot of information online about them. Youtube videos of the machines in action. Pictures. You'll probably need to set up a reverse block-and-tackle arrangement to get enough throw, but the cable and pullies will be a whole lot less expensive than a full hydraulic setup.
That leads to the full hydraulic setup. Many older plows were retrofitted with a hydraulic lift. Lift conversions were very popular on #8 Little Genius plows. You could get some cues from pictures online and fabricate up a lift conversion, and add a hydraulic remote valve setup to the tractor. It's the most expensive option, but the most practical and flexible, since you can then use the remote setup to lift ANY hydraulic implement.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
