3 pt hitch lift arms
Posted by Cue P. on August 02, 2012 at 08:08:51 from (24.91.179.50):
I have an IH 504 utility that has 3 pt hitch lift arms that can be set to either float up/down or remain locked. Problem is the right side (with leveling crank) will not remain locked despite putting the pin in the hole that is supposed to lock it in place. The left one is fine. Is there a fix for this short of getting another lift arm? Its making it difficult to plow when one side floats and one side stays locked.
