Re: MTA Diesel fuel filters
Posted by D Slater on August 02, 2012 at 11:06:30 from (184.15.26.242):
In Reply to: MTA Diesel fuel filters posted by Duanes on August 01, 2012 at 09:33:12:
Yes you can find SMTAD tractors and others with the final type stuck in them but unless the adapter kit was used its just sitting in there doing nothing. If you try a final in the auxilary hole you will see it just falls in without the o ring touching the bore unless it has the spacer in it. Also the housing hold down bolt shoulder needs to be like the final fuel filter bolt to reach the top of the filter.
Starting sometime on D264 engines in 400 tractors the filter base was changed to use the same final filter in both places. Don't know if you can find the adapter parts unless used. Probably could find a filter housing assembly for the filters from the last 65 % of 400D or all 450D tractors and put it on maybe as easy. Near where the housings bolt on will be a cast # One that ends with R1 is the late type. Since its a SMTAD and maybe you want to keep it original 99.9 % of people looking at the tractor wouldn't know by looking that it has the late filter housing assembly. Few of us around that could spot it though.
This post was edited by D Slater at 12:53:59 08/02/12.
Today's Featured Article - Tuning-Up Your Tractor: Oil, Oil Filter and Air Breather - by Curtis Von Fange. In the preceding articles we discussed some of the various aspects of doing a comprehensive tune up. Hopefully some light was shed on why we do or don't do certain things pertaining to inspections and order of events when doing a tune up. Perhaps some useful reasons were given for why parts fail and what to do about preventing part failure in the future. All these tips will help us think and reason out a problem in order to make our tune up last and, hopefully, keep us from spending extra mone ... [Read Article]
