Re: can a cummins motor fit in a 560
Posted by rhtx55 on August 02, 2012 at 17:27:18 from (207.119.62.8):
In Reply to: can a cummins motor fit in a 560 posted by dundeeaj on August 02, 2012 at 13:34:56:
What model of Cummins are you referring to ?
NT855, NTH, NTC, Big cam, Big cam IV, L10, M11, N14, Triple Nickel,K model, or something along the lines of a modern 4BT, 6BT, 6CT, IBX, ISX??
You can make just about anything fit with an adapter and flex plate, just have to be conscious of how much torque & vibration you would be putting through the 60 year old tranny, rear end, and final drives. I would also consider how much (if any) extra weight that it will place on the front end. Just consider the longevity of the modification, and the purpose you will be using the tractor for, just shows or working it.
This day & age, anything is possible, just depends on how far you want to take it.
This post was edited by rhtx55 at 17:30:59 08/02/12.
