Needing some F-30 parts or a donor tractor.
Posted by JDseller on August 02, 2012 at 19:24:12 from (208.126.196.144):
Brother has a F-30 that runs but it has a cracked block that has been welded years ago. He is wanting to find a good block without any cracks. Also years ago we put 40 inch tires and wheels on it to make it narrower to haul. He is wanting a factory set of rim/wheels for it. We would be interested in a whole non-running tractor if it had the needed parts. Just email me if you know of anything
