Drain the read end remove the bolt that hold the hyd. pump plat to the rear end and pop it off , unbolt the old pump replace the o/ rings install the new gear on the new pump tighten the nut that hold the gear on clean the gasket off the plate and the rearend houseing install a couple guide studs put the new o/ ring inplace with some grease to hold it there but the gasket on the guied studs and slid the plate back on and bolt down and refill the rear end along with a new filter. done.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
