McCormick Deering grain binder part
Posted by 55 50 Ron on August 02, 2012 at 21:34:12 from (209.131.230.128):
where should I start looking for a part for one of these old ground driven 8 ft cut binders?
A bundle forming spring is broken off and the broken off piece is missing. It's sort of "C" shaped.
Not sure what the correct name is for this part. It's not the packers. This spring (there are actually 3 of them) hangs down from above the bundle and raises up to let the bundle out when the knotter arms rotate through their cycle.
Thanks for any help. Ron
