Re: Super C Hydrolic Lift
Posted by IH fan on August 02, 2012 at 21:54:07 from (108.236.95.92):
In Reply to: Super C Hydrolic Lift posted by Janicholson on August 01, 2012 at 08:54:17:
Yeah, but he only has Touch Control and he won't be able to get a pull plow very close to the back of the tractor. That only adds to the perceived weight. Leverage to lift a pull plow off the ground far enough to drive anywhere is going to be tricky at best. If he could get it as close to the rear of the tractor as a mounted plow, it would be easier. Dad had a FEL on a C with no problem, but it's a different game what he's trying to do. If he could add a Fast Hitch or similar valve and a cylinder or two to the hydraulic system, something might be possible, but to lift it using the Touch Control I don't think is likely. Then if you get that figured out, you will need a LOT of weight on the front.
