Re: NEW $12. LED dash light on Farmall 560/460 Colby 560 ...
Posted by d282 on August 03, 2012 at 20:25:06 from (166.182.3.146):
In Reply to: Re: NEW $12. LED dash light on Farmall 560/460 Colby 560 ... posted by colby64 on August 03, 2012 at 19:08:52:
Is the tractor running in the picture............your oil pressure seems
low even if at idle.
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
