Re: different types of disks, what makes the choice?
Posted by oldtanker on August 03, 2012 at 21:50:19 from (66.228.255.239):
In Reply to: different types of disks, what makes the choice? posted by arod on August 03, 2012 at 20:19:46:
Check your soil type. It will dictate how much disk you can pull. My soil conditions allow about 2 foot of tandum disk for every 10 HP. Off sets pull much harder. A freind with a 4X4 250 HP Stiger can pull a 14ft offset but it sure makes that tractor bark. That tractor plays with a 28 foot tandum wing disk.
With a 100 HP trator if you find a deal on a smaller disk (I did, 14 footer for cheap) you can still run it. I'm running mine behind a 1206 (112 HP by the Nebraska test). I run in a higher gear at lower throttle settings runing at the desires ground speed for the disk. Saves a lot of fuel.
If I were you I would find a tractor first and then match implements to it.
Rick
