Re: different types of disks, what makes the choice?
Posted by larryanderson on August 04, 2012 at 05:22:02 from (75.105.32.39):
In Reply to: different types of disks, what makes the choice? posted by arod on August 03, 2012 at 20:19:46:
There are several different kinds for different purposes.The heavy offset disc are used mostly for deeper tillage and residue management and a 100H.P. tractor would not pull one .Regular wheel discs are used to level,incorporate chemicals,and to cut residue to make planting easier.Blade diameter[14/28 in]and weight make a difference in what size.Older lighter disc such as a JD BWA would let you pull a 20ft disc with wings where as a newer heavier disc might make 14ft a load.Discs are a dry weather tool and can cause compaction.We use field cultivators with levelers or rolling baskets as they come in larger sizes 60ft plus which requires around 500H.P.3 pt discs are used on a few small gardens and are usally small .Discs are not as popular as they once were and unless they are newer ones usually sell for around salvage.
The way discs are designed it is hard to have a level seed bed as they pull the dirt in and turn it but can leave a small furrow.
