Re: can a cummins motor fit in a 560
Posted by Huskers86 on August 04, 2012 at 08:12:32 from (70.198.5.17):
In Reply to: can a cummins motor fit in a 560 posted by dundeeaj on August 03, 2012 at 21:13:04:
Quoting Removed, click Modern View to see I'm guessing. The pump is weak or maybe low.
Compression is the problem. It could be injectors. I don't want to steer you the wrong way and waste your money. You can pull your pump and get it bench checked at a diesel shop for a start.
