Porting and polishing will help it floe air better, faster, and smoother. It probably wouldn't help at all with starting. Taking it in and having the valves ground and milling it will sure make a difference (if that is your problem) In my brief experience there are a lot of tractors out there that need the valves adjusted or even ground. The head work shouldn't be too much. Maybe $300 if you don't need a bunch of new valves.
With a good compression tester you should be able to determine if your low compression is being caused by your rings or your valves.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
