560 power steering
Posted by Sam Comstock on October 06, 2000 at 09:53:12 from (129.82.219.1):
I have traced my Farmall 560 power steering leak to a crack in the steering cylinder sleeve (the sleeve is inside the upper bolster, and the worm gear and piston are inside the sleeve). The local dealer says the sleeve is unavailable. A salvage yard said they won't remove them because they always break in the process, so they will only sell the entire upper bolster ($400). So here are the questions... 1. Any chance of removing and welding the outside of the sleeve? 2. Are the sleeve and the piston a matched set, or do the rings on the piston make up enough difference? 3. To remove the worm gear and piston do I need to first lift the upper bolster off the lower bolster? 4. Can I (temporarily) turn this into manual steering by connection the hydraulic supply to the return and capping where the are supposed to connect to the valve control assembly? I was so excited to get her started after sitting for so long, but the honeymoon ended pretty quickly!
Thanks in advance - Sam.
Home
| Forums
Today's Featured Article -
Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
