Re: blow by on new rebuild
Posted by The tractor vet on August 04, 2012 at 18:18:59 from (76.212.234.198):
In Reply to: blow by on new rebuild posted by 706v on August 04, 2012 at 10:58:09:
Ya need to hook it to a set of 4x16's and work the snot out of her now . One thing here i sure hope you staggered the rings on the pistons . Change the oil stuff in some #1 Case ih 30 weight Diesel oil and work her hard vary the engine Rpm 's and load If all you have done is mow hay at a set RPM and load that is not a good thing . when i rebuilt and engine i liked to run them in for a full day before i cut them loose to the customer then only CHORE work for the first thirty hours . Then turn them loose and run it like ya stole it . Show no Mersey take no prisoner .
