Re: popping piston ring noise
Posted by rhtx55 on August 04, 2012 at 18:20:28 from (207.119.62.8):
In Reply to: popping piston ring noise posted by Justin in mt on August 03, 2012 at 23:18:03:
I had a 46 H that was acting the same way, took the valve cover off & two pushrods had jumped out of place, the valve lash was WAY OFF. The two valves were starting to get "sticky" Got real lucky, I was to pop them loose with a few light taps, applied some tranny fluid and they freed right up, neither push rod was bent. Set the valves & it ran like a new.
