Re: 806 hc
Posted by Harold H on August 05, 2012 at 06:30:44 from (12.23.230.67):
In Reply to: 806 hc posted by Doofarmin2 on August 04, 2012 at 16:41:44:
That tractor is either a F806HC that somebody removed the wide front axle and substituted a cotton picker guide wheel, or is a common Farmall 806 that somebody got the rear axles and drop boxes from a salvage tractor to raise the tractor and pass it off as a F806 HC. What does the serial number plate show? A single front wheel was not a factory option on a F806HC.
Harold H
