Posted by Janicholson on August 05, 2012 at 06:57:52 from (96.24.99.126):
In Reply to: Re: got the cub home posted by ericlb on August 05, 2012 at 06:46:40:
The axle got hot enough to bend, The spindles (at the hub)are probably 4130 alloy and tempered. when heated and allowed to cool in a ash pile, they anneal (become as soft as they can ever be) and will now bend with stress. the threads will be soft, and the spindle shafts (vertical shaft in the housing will also be annealed. If the building was cooled with fire hoses, the resulting quenching can make tough things brittle, exactly the opposite of annealing. The factory heat treatment and hardening was scientific and done well. (even if they do break when stressed). I gotta say unless they are rechecked for dimensional accuracy, and re heat treated (way expensive) they are toast. Sorry, Jim
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
