Re: more horsepower
Posted by Tom Fleming on August 05, 2012 at 16:30:20 from (173.233.7.210):
In Reply to: more horsepower posted by WVFarmall on August 05, 2012 at 14:08:21:
Let me put some perspective on what has been said, with an additional suggestion.
1.) Over bore sleeves and pistons. Also, make sure the pistons are high compression.
2.) Shave the head a bit.
3.) carb work is fine to provide more fuel, but then it is not stock.
4.) have the intake ports polished.
5.) Adjust the timing correctly, as if you up the compression enough, you will have to run at least mid-grade fuel if not super.
These things can be done and I believe it would still qualify as "stock". However, I am NOT a puller, nor am I am expert on what the pulling requirements are. I do know how to "motivate" an engine without stroking it or having a custom ground cam.
IHC offered overbore and high compression pistons. Not sure if they offered different jets or venturi's for more fuel flow.
