Posted by Heat Houser on August 05, 2012 at 18:13:02 from (69.66.35.73):
In Reply to: more horsepower posted by WVFarmall on August 05, 2012 at 14:08:21:
Only two ways to get more horsepower, increase the engine's torque or increase the RPM.
To increase the torque you need to increase the pressure in the cylinder from the burning of the fuel. This means that you must increase the amount of fuel and the amount of air with each burn. Expensive to do as you will spend big bucks to get there.
Increasing the RPM will increase Hp but may be expensive if the engine blows up from too much RPM.
The IH engineering department spent many hours calculating loads on cranks, rods, tranny gears, axles, etc. I suspect they have it fairly well balanced when looking at the total system.
Of course, everything has a reserve which is intended to be used up in a long life. If you go over the design, low life will result.
Just my 2 cents.
BTW, will be in Charleston WV tomorrow...(Nitro actually)
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
