Re: H Alternator
Posted by Janicholson on August 05, 2012 at 21:22:21 from (96.24.99.126):
In Reply to: H Alternator posted by Al in Mn on August 05, 2012 at 21:03:04:
Hitachi 14231. Is the Model Number. "L" on the Hitachi is the same as #1 on the Delco 10SI. "S" on the Hitaci is the same as #2 on the Delco. Use the diode for the L wire with the band toward the alternator. It is an international tractor to me the origin of the best fit part makes no difference. (it could have Lucas stuff on it. Nah.) Jim
