Re: H Alternator
Posted by 1946 m on August 06, 2012 at 04:52:54 from (63.170.112.38):
In Reply to: Re: H Alternator posted by DeltaRed on August 05, 2012 at 22:02:29:
If you will drill a hole in the end shaft and tap treads in the shaft you can use the same pully as the gen adjust just like with the generator. I have have a super h that is fixed that way it is a tight fit but does work. Use a delco alterator just like pictured.
