Re: Spark plugs for Farmall H
Posted by rustyfarmall on August 06, 2012 at 08:59:26 from (67.55.162.174):
In Reply to: Spark plugs for Farmall H posted by John Fulton on August 06, 2012 at 08:31:50:
The industry developed the resistor type plugs sometime back in the 50s (I think) to suppress the static given off by the ignition system which interfered with TV, AM radio, and other communication devices.
It basically takes a little stronger spark to get the same results with a resistor type plug than would be needed with a non-resistor plug, which means the non-resistor plug SHOULD give better performance.
I've only just brushed the surface with my explanation. It gets a LOT deeper if you want to dig. JohnT can explain it better.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
