Re: Spark plugs for Farmall H
Posted by John T on August 06, 2012 at 09:29:00 from (216.249.82.117):
In Reply to: Re: Spark plugs for Farmall H posted by John Fulton on August 06, 2012 at 08:31:50:
Like Rusty noted resistive suppressor (some are carbon core instead of wire) wires n plugs came into the picture (among some other reasons) partly to reduce RFI noise to keep the radio quieter. The thing is the coils HV secondary output of a relatively low energy Magneto matches up much better if theres little resistance/impedance in the plugs and plug wire circuit (NOT counting for the open gap), so regular non resistor plugs (what was used when mags were developed) are preferred. While that issue is less relevant in a batetry powered coil distrubutor ignition I figure one may as well use a non resistor (3116) plug there also. While its not much, Id just as soon discharge all the avaialble stored energy the coil has to offer by discharging it across the plugs gap (volts x amps x time) versus as I squared R heat loss in resistor wire or resistor plugs. This is similar to my preference of bigger then stock battery cables on 6 volt tractors, say 0 or 00 versus No 1 or 2, Id again (regardless if not all that much difference) just as soon discharge it in the starter then I squared R heat loss and voltage drop in the cables, since when its extremely cold, the starter may draw twice the normal current (say 300 amps instead of 150), battery voltage may drop to 4.5 instead of 6.3, and ALSO battery efficiencty is greatly reduced at cold temps.
But Hey Im just wired that way and am conservative and yes I MIGHT over build and over design now n then, its just how I was raised n trained. I doubt the performance would be much (if any) different if you used 386 instead of 3116 and unless its extremelyyyyyyyyy cold your old girl would probaly still start heck even if you used 4 gauge cables lol
BUT THATS MY STORY N BY GOLLY IMA STICKIN TO IT
John T A CONSERVATIVE what can I say
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
