Re: bringing a battery back to life?
Posted by Farmallboy15 on August 06, 2012 at 18:55:40 from (184.20.168.81):
In Reply to: Re: bringing a battery back to life? posted by rhtx55 on August 06, 2012 at 18:01:21:
It is a 6 volt. I had topped off the acid. And put it on the
charger again. I hit it a couple times with 100 amps to try and
knock some corrosion off the plates. If it still doesn"t charge
after 24 I will try to drain and refill it...
